The dunk meter in NBA 2K22 is an exciting new feature
Messagede Skyzhay » 13 Avr 2022, 04:49
The dunk meter in NBA 2K22 is an exciting new feature NBA 2K22 MT that is a new addition to the game. It is similar to the shot meter as you have to set the time for your layup or dunk into the green box on the right side of a player. Timing is crucial to Dunks in NBA 2K22 since all finishes require the shot meter regardless of layup, dunk, or alley-oop.
The size of the green box will vary. The higher the dunk score and place of the player will result innn a higher chance to complete the move. If an opponent is blocking the paint, it will likely lead to a more difficult finish. Specialties and traits like Lob City Finisher or Fearless Finisher offer players a extra boost when they attempt to finish dunks that are close to the rim.
The dunk rating and requirements will be based in the length and attribute selection of the athlete. The player should be at minimum an 84-inch driving dunk and 70 or higher in vertical ratings in order to finish a professional alley-oop or contact dunk. Additionally, they should have at minimum 92 inches of standing dunk as well as 80 or higher on their vertical rating in order to get elite dunks, such as poster dunks , and 360-degree jams.
You need to press to either the R2 or RT can i buy mt in 2k22 trigger and then keep your right stick in the direction of the hoop while you perform a two-hand dunk. The two-hand shot is one of the dunks that are easy to perform with NBA 2K22.
Skyzhay
Utilisateurs parcourant ce forum: Google [Bot] et 3 invités
