MMOexp ARC Raiders: What Makes This Spot Good
Toutes les rencontres Celica...
Messagede Stellaol » 10 Déc 2025, 09:29
You do not need to extract after repairing the panels-the quest completes instantly. However, extraction is always the safest way to ARC Raiders Coins keep any extra loot you may have collected along the way.
The closest extraction point is:
Western Station (Northeast of the Solar Panels)
This station offers a relatively short and direct route, though it may still be contested. If you want to guarantee a safe exit:
Stick to alleyways and rooftops.
Avoid open plazas where ARC patrols roam.
Listen for enemy raiders, especially above you-high ground is popular in Buried City.
Once you reach Western Station, extract and enjoy your rewards.
Final Tips for After Rain Comes
Always store mission materials in safe pockets. Losing them in combat means restarting the whole trip.
Scout Grandioso Apartments before committing to the repair. The area is a magnet for ambushes.
If you're low on materials, buy from Celeste. It's faster than searching.
Use rooftops for safer travel. Vertical movement is your friend in Buried City.
The After Rain Comes quest is one of the simpler repair assignments in Arc Raiders, but the danger comes from the area, not the objective itself. Go prepared, stay alert, and you'll have those solar panels humming again in no time.
Arc Raiders Guide: Best Locations for Voltage Converters
Arc Raiders is full of materials, scrap, and components that you'll gather as you explore the harsh environments and raid-infested battlegrounds. While many items can be safely sold or recycled for a quick profit, others play a critical role in crafting the gear you need to stay alive. One of the most important mid-tier components you'll come across is the Voltage Converter-a valuable electrical material used to craft both the Heavy Shield and Showstopper Grenade, making it essential for players looking to expand their defensive and offensive build options.
The good news? Voltage Converters are much easier to track down than some notoriously rare drops like Rusted Gears or Industrial Batteries. Below, we'll cover exactly where to farm Voltage Converters, which locations offer the best yield, and what ARC Raiders Items you can salvage if you prefer crafting them through recycling.
Where to Find Voltage Converters
Voltage Converters belong to the Electrical-type material category. This means they most frequently appear at points of interest (POIs) marked with the lightning bolt icon. Any electrical facility, substation, or tech-heavy zone has an increased chance of spawning them, especially in areas full of fuse boxes, computer banks, and power consoles.
While Voltage Converters can drop at many locations across the game, some hotspots consistently outperform the rest. Here are the three best places to farm them:
Pilgrim's Peak (The Blue Gate) - Best Overall Farm
Pilgrim's Peak is widely regarded as the top-tier location for Voltage Converter farming-and for good reason. This high-loot POI offers both quality and quantity:
Why It's the Best Spot
Electrical-heavy environment with fuse boxes, power junctions, and consoles everywhere
Basement area packed with breachable panels that regularly drop Electrical items
Very high chance of finding Processors, Sensors, and multiple Voltage Converters in a single run
Classified as a high-tier loot zone, meaning blue and even purple-tier items appear far more frequently here
If you want a steady, reliable source of Voltage Converters, Pilgrim's Peak should be your primary target. Because it's such a lucrative location, expect increased raider traffic-both friendly and unfriendly-so move cautiously and clear rooms before looting.
Power Generation Complex (Dam Battlegrounds) - High Density, Large Layout
The Power Generation Complex, located in the northern section of Dam Battlegrounds, is another excellent place to hunt Voltage Converters. Although it's not quite as dense with electrical loot as Pilgrim's Peak, the sheer size of this facility makes up for it.
Multiple large wings packed with computer terminals and breachable metal boxes
A big, sprawling basement with steady electrical loot drops
Lower-tier areas mixed with mid-tier rooms, offering diverse loot opportunities
Voltage Converters don't appear in tightly packed clusters here, but the quantity of searchable containers and the broad layout give you plenty of chances to find them. Just be prepared for some chaotic combat-Dam Battlegrounds is often swarming with cheap ARCR Coins both ARC units and raiders.
Stellaol
Retourner vers Rassemblements
